what octane fuel does the Excalibur require? What about teh ZR6?
fuel reccomendations
I believe the Excalibur preferers 87 octane, and the ZR-6 wants 89 octane. The computer on either engine will adjust for a lower octane gas, if the higher is not available. There is no advantage in running a higher octane, and you will lose power. If your boat is sitting over the winter, use a fuel stablizer, also. PCM recomends Sta-Bil.
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
RE: fuel reccomendations
All PCM engines since the change to GM in 2002 are calibrated for 87 octane. Pro Sport, Excalibur, and ZR6. There was a sticker on the early Excaliburs that stated that it needed 89, but the sticker is incorrect, according to PCM.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Re: fuel reccomendations
Originally posted by DanielCI believe the Excalibur preferers 87 octane, and the ZR-6 wants 89 octane. The computer on either engine will adjust for a lower octane gas, if the higher is not available. There is no advantage in running a higher octane, and you will lose power. If your boat is sitting over the winter, use a fuel stablizer, also. PCM recomends Sta-Bil.
