1. What interior feature does Nautique pull from to make the pillows, primary or secondary?
2. What Acme prop # is stock on the new hull Paragons? I had tuned my 2020 to perfection (ZZ8) prop-wise (and it was different than stock, slightly lower RPM - prop)
3. Tongue weights people are seeing with the new 24/25 boat/triple axle trailer. (This doesn't matter much; I'm just curious)
Thank you.
Thank you.
