Ballast pump replacement
  • Deibs
    • Feb 2007
    • 1
    I am in the process of replacing the ballast tank filler and discharge pumps on my 04 206 Air Nautique. The factory ones do not fill and discharge properly. I have been advised of using the Jabsco model pumps that do not require priming. Has anyone gone through this process and if so, do you have any suggestions etc on the type of pumps and the necessary parts to complete the swap. Much appreciated. Deibs.
  • goodfoot00
    • 39
    • Noblesville, Indiana
    RE: Ballast pump replacement
    I have two aerator pumps that came out of a SAN. They work fine. I'll sell both of them to you for $35 shipped.
    1995 Super Sport, GT40 with EFI
    NDT Tower, plumbed ballast, PP
    • Quinner
      • 2246
      • Correct Crafts
      Check with your dealer, I believe there was a recall on the ballast pumps on my 05' 206.
      If no recall perhaps this would be considered a warrantee issue?
      • iceman991
        • Jul 2006
        • 138
        • 707
        • 81' ski nautique 20th anniversary edition 05' SANTE 210
        ballast pump replacement
        .................on my 05'210 SANTE my factory belly ballast valve seems to drip a bit, not much, but at the end of a daily session their is a bit of water in the hull, is that normal and should i replace them since we're on the topic. when i pull the plug after a session it sometimes will drain for 5 seconds sometimes longer, a good gallon sometimes! o and it has a dripless packing gland as well.
        thank you,
        ice
        • triplered
          • Jan 2005
          • 31
          • Ramsey, MN
          • 1986 Ski Nautique 1996 Ski Nautique 176
          I suspect the plumbing would be significantly different. I believe the exhaust hoses running from the inlet to the tanks is 1 1/4. I think your '04 system uses a set of hoses that is smaller (bilge hose). So, I think you would need to adapt the outlets etc., etc. A bit of surgery
          but probably do-able. :???:
          • OldFart
            • Jun 2004
            • 401
            • South of North & East of West
            i am not sure Deibs, but ur '04 pumps are different than the '05/'06. ur 04 may have 2 pumps PER tank vs the single pump per tank used now. & if u ever convert to jabsco, be sure to get the "silicone-based" impeller (even if u have to buy it separately). jabsco's standard impeller s@cks!
            \"The voices aren\'t real...but they have some good ideas.\"
