I Pod Compatible Stereo System
  • passdarock
    • Sep 2006
    • 2
    There is a screw on the side of your water pump. Looking at the end of your Ford engine, that has the v-belts, on it, towards the transmission, if the engine rotates clockwise, the screw goes in to the engine. DO NOT LOOK AT THE PROP. YOUR TRANSMISSION MAY OR MAY NOT CHANGE THE ROTATION! If your engine rotates counterclockwise, the screw goes out.
