Pulling water toys from the lifting ring
  • rocco
    • Jan 2004
    • 167
    • Virginia
    Pulling from the ring....I pulled 5 tubes at one timefrom my old 84 ski..
    about every month and I checked the ring every time..It stayed tight
    never any movement from the ring...When you pull another boat in that is in need,,What do you tow with, The Ring or the Ski Pylon.
    The ski Pylon is about 3 to 4 feet tall,and the Leveage is greater for it to Bend or Break...The Ring is shorter too....(Which One is Best)
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      RE: Pulling water toys from the lifting ring
      Rocco, you are referring to the MasterCraft Tow Ring, right ? I used to have one of those on my 90 SN....
      the WakeSlayer
      1968 Correct Craft Mustang
      • stevieb
        • Mar 2007
        • 48
        The 216 warning sticker said no towing from the grab rail...that is correct..but it said it was okay to tow up to two people from lifting ring. Pretty clearly stated....if the dealer weren't an hour RT drive I'd shoot a picture and post it...
        • Quinner
          • 2246
          • Correct Crafts
          Steve,
          My reference was from my 05' 206 w/tower, boat is here camera is not, the transom sticker on mine says "water sports tow point" nothing about the lifting ring. The owners manual shows the sticker however print is too small too read. Appearantly they have changed that sticker since 05'.
          • Quinner
            • 2246
            • Correct Crafts
            Here is a Pic of the sticker on an 05'
            • DavidF
              • Sep 2004
              • 611
              • Austin, TX
              #21
              Originally posted by chris196
              I had a look underneath things this weekend. The front lifting ring has a nice big aluminum backing plate on the underside of the deck. It looked really solid. So, I thought if it's that way in the back, I'd be pretty confident it could handle it.
              However, the back lifting ring didn't have a backing plate like the front ring. So, I don't think I'll pull off of it. I wonder why the front has a backing plate, but not the back.
              The backing plate is to keep the deck from flexing downward when people step on the deck. If no plate, the screws which keep the ring from rotating would pull out of the fiberglass when someone walked on the front deck of the boat. The rear deck is not as large and does not flex like the front.
              My '93 SN has a tow spool on the back deck because the lifting rings are below the platform. the tow spool (as designed by CC) is simply bolted through the fiberglass with an aluminum backing plate...Just like the lifting rings. Go ahead a pull from the lifting ring, it can take it...the deck if very thick.
