I know there have been many threads on props etc, but I am looking at a 95' 196 CB and wondering what would be the best prop set up as far as cleaning the wake up a bit (softer). I know the tsc 1 hull would be a better choice but this seems like a pretty good deal. Looking for some experienced opinions with this hull as far as course skiing. Will a prop make any difference in wake size, softness?
Re: Prop vs Wake
We've tried these props on that hull:
Federal 3-blade (stock)
OJ Legend 4-blade
Acme 422 4-blade
Acme 470 3-blade
We saw a minor wake change going to the OJ from the Federal (for the better). There was little (if any) difference in wake shape between the OJ and Acmes from what I remember. As far as performance goes, the 470 is the best of the bunch.
I'll be testing all the applicable Acme's and OJ's this spring. In addition to performance measurements, Ill snap some pics of the wakes.1990 Ski Nautique
NWCT
RE: Re: Prop vs Wake
My oj has a softer pull then my acme. I was told a larger prop spinning slower, (even 100-200rpms) has that effect. If your lake has a lot of debris, then stay away from the machined props, they tend to get damaged easier then the cast. Just a few things to consider.2005 Ski Nautique 206 SE, Acme 422, PP SG 8.0, ND Tower
Prior Boats:
1999 Ski Nautique GT-40
www.skiersofknoxville.org
Since I've got a different boat, this may not help all that much, but just in case it might, here's a link to a write up I did after a prop comparison between the 13x12 Acme and 13x12 3 OJ XMP (both 3 blades). As far as wake goes, the acme knocked the rooster tail down a bit more, but the wake overall was slightly more turbulant. I've got side by side comparison pictures from 24--36 mph. The OJ has a softer pull, but not nearly as much tug out of the hole.
http://www.bhammonster.com/shoot-out.htm1998 Ski Nautique (Red/Silver Cloud), GT-40, Perfect Pass Stargazer 8.0z (Zbox), Acme #422, Tunable Rudder.
JC, the prop will make a difference in the wake on that hull. Between the stock federal and the 4-blade OJ I noticed a pretty big difference in rooster tail size and hardness at 15 off. Overall that hull is way ahead of it's time and will be great for you in the course.
