RE: 2001 dd
Take a look at this link for a photograph of the TWC and TSC hulls side by side.
http://correctcraftfan.com/reference...ex.asp?page=04
In answer to your question, NO, the TWC hull is not the same as the VDrive hull. TWC was
designed as a wake specfic boat. As you'll see from the photograph, TWC has lifting strakes, and a step down in the hull. This was designed to get the nose up, the stern down, and to create a larger wake. Pro Air, which I believe was only made for 3 or 4 years,
is the only model with this hull.
You can certainly ski behind the TWC hull, but it will not be as good as a TSC hull for waterskiing.
Air Nautique- is a Sport Nautique, with a tower(usually) , built in ballasts, and some special graphics. It has the TSC hull. BKH
