electric hatch, battery dead
  • isbtown
    • Aug 2006
    • 139
    • Dahinda, IL
    I haven't even looked at it, but just thought of this... if I have an electric hatch on the 2000 SAN and the battery dies... isn't the battery under the hatch or is it somewhere else that is accessible?
    http://www.onlyinboards.com - over 1000 new and used inboard boats. Over 200 CC\'s on the site.
    http://www.wakereviews.com - Submit 3 Reviews, get a free Vinyl wakeboarding sticker!
  • MHayes
    • Aug 2004
    • 830
    • Roswell, GA
    RE: electric hatch, battery dead
    It's under the hatch. There have been several threads on this in the past when someone's battery died. Do a search and you should be able to get more information.
    2001 Air Nautique
    • jonfo
      • 385
      • Bellevue, WA
      • 1990 SN 2016 G23
      The rear seat back lifts out on the 1995-2000 super sports giving you access to the battery on the starboard side. On my 1995 the sound panels behind the seat were a bit difficult to move though.
      -Jon
      16 G23
      07 220 TE
      05 211 TE
      95 SS (210)
      89 SN
      • skiswm
        • Mar 2005
        • 165
        • SF Bay Area/Truckee CA
        In my many times of having a dead battery, I can confirm you lift out he back seat (be careful there is a bracket holding in place) then you probably have a wood backer you will slide to the side to give you accress. It's not easy, you still have to get under the back and undo the battery and either lift it out or run the charger into it.
        • Osmosis
          • Feb 2007
          • 52
          If I'm not mistaken, is'nt there a manual release strap...
          • hollister
            • Nov 2003
            • 40
            • Loveland, OH
            isbtown
            I had the twin to your boat, and had chronic battery issues. When the battery goes dead, lift out the back seat, slide the starboard sound panel over, undo the battery cover, and attach your charger or jumper cables. If I was going to lay the boat up for any amount of time (> 1week), I would simply attach charger cables prior to closing the hatch. Installing a battery isolation switch helped also, and is a pretty simple job.
            There is no manual release strap.
            Current Boat => 2007 SAN 220 TE
            Last Boat => 2000 SAN
            • isbtown
              • Aug 2006
              • 139
              • Dahinda, IL
              yeah, sounds like the isolation switch is what i need. I did access the battery today, thanks for all the help!
              • isbtown
                • Aug 2006
                • 139
                • Dahinda, IL
                installed the battery switch today, that was very simple. boat is back together and ready for the maiden voyage this week.
