Wake roll first 220
  • baller220
    • Jun 2007
    • 8
    Wake roll first 220
    I have a 2006 220, One of the first. No matter how I weight the boat I always have wash. Any help. Note I have tried the 60 40
  • DRAGON88
    • 529
    • Eugene, Oregon
    • 1999 Sport Naqutique 2005 Super Air Nautique Team Edition
    RE: Wake roll first 220
    What speed/line length are you riding at? You shouldn't be having any troubles with the wake not being clean unless you are going really slow. I'd get a GPS and make sure my speedo's are properly calibrated at 23mph or so.
    How about \"Chales\"?
    RIP Nikolai (\'05 SANTE) 5/23/05 - 4/30/06
    • baller220
      • Jun 2007
      • 8
      I run between 23 and 24. I have tried lead weights and the fly high water sacks.
      At Factory weight it rolls. Also it will roll when I have 2400lbs of extra weight. Do you think a new prop will help?
      • PARA
        • Jun 2006
        • 152
        • cairns,qld,Australia
        talk to pj dave I believe he has his 07 220 dialled in
        08 210 te
        07 210 te
        06 220 te
        wwwpegasuswatersports.com.au
        • DRAGON88
          • 529
          • Eugene, Oregon
          No, a new prop isn't going to help. Do you mean the wake washes out on both sides? Again what length of rope are you using? Usually putting more weight in the bow will cause the wake to clean up. My only advise is to just keep experimenting, weight is weight so lead or fatsacs really have the same effect. What are you setting the hydrogate at?
          • baller220
            • Jun 2007
            • 8
            hydrogate is at 1. that is when it is the best. when it is at 3 both sides wash. I ride at 70 to 75, I will try more weight in the front today. 60% up front and 40% in the rear.
            • indo
              • 84
              • Smith mountain lake
              ive rode behind this boat and we have had a huge problem with the wake washing. it seems with factory wieght it should be clean. but its not. awesome boat other than that! does anyone know if there is any truth to the molds being tweaked mid year the first year the 220s where out?
              • jos
                • 154
                • Netherlands Boxtel
                Call ACME and ask. More or less cupping of the prop is of influence on bow lift / pulling down the rear. Possibly send in your prop and give it some extra cup height.
