Gas shock screws ripping through fiberglass
  • Rangertrace
    • Jun 2007
    • 48
    • Athens, Texas
    We recently purchased our first Nautique, a 2004 SV211, Limited with 53 hours on the engine. Quite a jump from a Triton fish and ski!! We love the boat and will be Nautique drivers from now on. For the most part, the boat looks brand new. However, I have had some minor issues with the screws that secure the gas shocks to the fiber glass. The shock that lifts the main battery storage lid has broken loose twice. The dealer "quick" fixed it by moving the top of the shock down, just below the first holes and screwing them in again. Now, it haas broken loose again. Is this a common problem? Is there a proper fix that does not shut the boat down for a couple of weeks? Any advise would be greatly appreciated.
  • lukeduke95
    • Nov 2004
    • 57
    RE: Gas shock screws ripping through fiberglass
    Thats funny. I have an engine cover out of newer boat (2 piece) and the shock screws tore out a big chunk right where they mount. Frustrating, but it also sits tighter in the back now without all that upward pressure on it.
    • Rangertrace
      • Jun 2007
      • 48
      • Athens, Texas
      I fixed it last night by moving the top of the shocks down just below the last holes. Hopefully this will hold. If it doesn't, eventually I will run out of space and this quuick fix will not work. I guess if it's good enough for Buxton marine, it is good enough for me!!
      • Andrew
        • Aug 2005
        • 891
        • Tuscaloosa, AL
        eventually, ur probably gonna have to repair the area with an epoxy or sumthin
        • ffmedic74
          • 835
          • Lexington, KY
          You might want to buy some aluminum stock for the backside as plating material and use some silicone to "beef" up the system.
