MNSuperAir - I just put the Fly High Bow Sac in my SAN and all I can say is that it is the bomb. It probably gives me about another 300 lbs. in the bow and that appears to be the spot where I needed weight the most. I currently have a ski locker sac as well but it is an older Phat Buddy sac which holds about 450 lbs when full. I am pretty sure that 20x20x50 fly high sac would work but you may not be able to fill it all the way full. I have also heard some people got Fly High to make a custom triangular sac for their ski locker that used all of the available space down there so you may want to call Fly High to see if you could order this sac from them as well. Good luck with the system and definately give a look at the integrated bow sac from Fly High and you will like the results. I moved my existing lead from the nose to the side gunnels next the driver and the lift up passenger seat and the wake was basically perfect.
MNSuperAir- I have a 99 SAN also w/out a belly tank, but with a huge ski locker. I have the Fly High Pro X series tube sac 62"x16"x10" . I picked it up at wakeside.com. I can fill this sac to the maximum weight, but with little room to spare. I don't think the sac you are looking at will fit in the belly ski locker. I don't know if you've already made your decision, but hope this helps.
