prop puller...
  • tdc_worm
    • 542
    prop puller...
    ...anyone run into a situation where a standard C clamp shaped prop pull would not fit in between the blades on a 4 blade prop?
  • azwakeboarder
    • Feb 2007
    • 83
    RE: prop puller...
    Yup, I had to get one with a twist in it. The offshore guys use them. Don't get the one with the three or four bolts that you tighten, it's terrible.
    • noti_dad
      • Jan 2005
      • 214
      yep. My old c-clamp style 3 blade puller would not work on a 4 blade. But my buddies 4 blade works on both 3 & 4. The neck is narrower and let's it slip between the ,closer, 4 blade. I just ground the neck on my 3 blade and it works like a charm now.
      • tdc_worm
        • 542
        thanks... looks like i get to go spend more $$$$!
        • Justin1933
          • Feb 2005
          • 240
          • Orange County, CA
          • 2005 SV-211
          I did the same as Noti dad...I filed mine down and now it works like a charm....No need to buy a new one
          • tdc_worm
            • 542
            yeah, but it may pi$$ off my budy if i give him a modified puller back, ha ha ha!
            • Justin1933
              • Feb 2005
              • 240
              • Orange County, CA
              • 2005 SV-211
              that it would....
              • darrel409
                • Jul 2004
                • 566
                • San Dimas, So. Cal
                My good friend did this.....
                mark on your puller where it binds and doesnt fit. Take a grinder to the puller. Just dont make it too thin/weak...Worked for my friend. Now his old 3 blade puller will do 4 blades.
                ^^^guess i should read first. :|
