i have a 2000 air with keyless ignition. and a motorized moter lift. when i try and close my motor hatch the boat tries to start. can anyone help thanks..
RE: my keypad is having probles
Check your battery Low voltage does really weird things If the battery is fully charged check the ground wire by jumpering a ground wire from the battery to the ground on the hatch cover motor. I would guess it's a the low or bad battery.Nautiqueless in San Diego
