Looking to do the normal sound improves this winter. Being the battery box is not big enough for a second battery, has anyone installed a Switch and second battary in their 216. I could put it in the front like the old sports, but I finally have a place for the anchor. I was thinking the ski locker maybe. We all know you can't get a ski in there. Any suggestions. Pictures would be helpful.
Originally posted by wetfootI asked the same question some time ago and as I recall someone had recommended a gel battery in the bow storage locker in front of the driver.
I hope this is helpful.[color=blue][size=2][b]I Nautique, therefore I am.[/b][/size][/color]
- Aug 2020
- 1343
- Horseheads NY
- 1999 Ski 2000 Sport 2004 SV21 2007 216 1992 Malibu flightcraft 2008 210 2006 ski 2012 - 210 2016 BU 23lsv 1998 Sport 1997 Super Sport
looking for a back up battery. Switching between the 2 on different days. I don't have a system that requires a whole lot of load. I did this by design. I will more then like put in a battery switch, 3 position, so if I had a need to parallel the 2 I could. I only have 3 AMP, 2 JL 300/4 and 1 500/1 Sub. I'm not much into big bass, so I don't have much draw. These amps are the most efficant I could find. I guess I don't see the need for a Isolator or cap in the system. I will try to sketch the system soon. Still trying to come up with a plan.
- Aug 2020
- 1343
- Horseheads NY
I found room under the dash. Thinking of making a trap door to get it in and out. I don't have a heater, so I have the room. Many only concern is all the wiring and cables.
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
I added a second battery to my 2003 210 when I had it. I really liked that setup. I got an Optima blue top, which can be mounted in any position, and mounted it under the rear bench seat in the spot directly behind the driver. The stock battery was on the other side of the rear bench. Since there was no cutout in the floor for the second battery, I had to lay the battery on its side. With Optimas, that's fine. I added a Hellroaring battery isolator/combiner. Everything worked perfectly. I'll see if I can find the old thread with the details.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
- Aug 2020
- 1343
- Horseheads NY
Thanks Jeff. Not sure I completely understand the purpose or if I need an isolator. Not sure I understand how to wire it in either. I have been using Kenetic Power cells for batteries simalar to an Optima except 1.578% percent x stronger. I have the 2200 Amp battery. And if I remember correctly was good for 198 Amp hours. I just through 1 in the boat last year until the end of summer. I'm really just adding a second battery for peace of mind.
Good luck on ordering your new boat. My dealer has an all black one and I think it looks great.
