steep driveway??
  • onenautiqueone
    • Apr 2025
    • 89
    • Nor Cal
    steep driveway??
    Trailer is draaaaggiing... :???: Any one have the same problem of having a steep incline driveway. Im looking into a new trailer that is higher off the ground, but would like to find something cheaper.
    Any Ideas??
  • chris196
    • Mar 2007
    • 223
    RE: steep driveway??
    check out this thread:
    http://www.planetnautique.com/index....er=asc&start=0
    this is how I handled mine.
    • CAN'TSKI
      • Feb 2007
      • 205
      • Boerne, TX
      • 2008 196 Limited 2007 211 Team 1995 MC Prostar 190 Tournament
      Can you put taller tires on it? Wheels?
      • 54T
        • Oct 2006
        • 49
        Onenautique,
        If you examine the thread that chris196 suggests you will see tha part that I put on my Ramlin to deal with the driveway. Just want to say that it works great.
        • east tx skier
          • Apr 2005
          • 1561
          • Tyler, TX
          Not to repeat myself from that thread, but I, too, have a steep driveway. What I tried with the old trailer...
          Approach at an angle
          Drag wheels (go with poly over steel as steel will leave marks).
          Drop Hitch
          Lifting blocks/different springs.
          With the new trailer, Dorsey had a kit with poly drag wheels that worked great. My new trailer has larger wheels, too. With a 2" drop, approach at an angle, and the drag wheels, I minimize my contact (and what contact there is is just the wheels).
          • jjackkrash
            • May 2007
            • 498
            • PacNW
            • 2021 Ski
            Drop Hitch
            Air-leveling suspension (on the tow vehicle) with a manual adjustment switch may help the situation as well. My vehicle came with it but I don't think its a very expensive aftermarket product.
            • hundo
              • Nov 2004
              • 210
              • York SC
              I think its between $500-1000 depending on what brand. Firestone is one, most people use it with trucks when hauling a camper or trailer. You could install it on your trailer (air bags) and run a line all the way up to your cab of your truck so you could inflate the bags when needed. I think doing it this way you don't alter the trailer or the ride making it a harsh ride beating your boat up. I had the rollers on my trailer and it worked but it still put a lot of stress on the trailer. With the airbags you just hit the compressor and it raises the suspension. (I don't think it will work with a torsion bar suspension, leaf only)
              Don
              • C-Money
                • May 2007
                • 74
                • Kansas City
                I turned around in a neighbor's steep driveway down at the lake last summer. They had just fixed it up real purdy with fresh blacktop. I left my mark on it right where the road meets the drive... I feel like a jerk every time I drive by... Oops!
                I like the air bag lifter on the trailer idea! I've got a Range Rover with the manual suspension, but I have not towed with it yet. Now I'm anxious to see if that can help keep me out of scraping situations. Makes sense...
                • ffmedic74
                  • 835
                  • Lexington, KY
                  My trailer is on the thread attached above. My driveway had a VERY steep incline and rode on the delrin wheels only and worked great!
