Originally posted by lakeeriemonster
View Post
As another datapoint, I had a 2014 230 with the ex343 that I weighted with 800lbs of lead mostly in the bow and 750's in the rear. I initially had the 1235 and switched to the 2079 prop because it struggled to get on a plane for wake boarding. I never had an issue with surf speeds. If you only plan to surf with full ballast then the 1235 should be fine.
Originally posted by Jeff88 View Post
Im in the same boat here. 1235 stock prop with 343. Have the 750s plumbed in with wakemakers divider supports. No issues with surfing with 8-10 people. I also took the trays out the first day and put them in the basement. They look nice but we just throw the jackets on top of the bags. No way you can keep the trays in when you completely fill the bags. No bow weight for me.
I ordered the support brackets right away based on what everyone on here recommended. I'm going to add a couple more divider pins this winter just to keep them from sliding up. Put you certainly need them with the 750s.....they'll bend your stock bracket
Originally posted by Davew0815 View PostAs another datapoint, I had a 2014 230 with the ex343 that I weighted with 800lbs of lead mostly in the bow and 750's in the rear. I initially had the 1235 and switched to the 2079 prop because it struggled to get on a plane for wake boarding. I never had an issue with surf speeds. If you only plan to surf with full ballast then the 1235 should be fine.
I'm thinking about ordering the 2079 as a primary prop and keep the 1235 for backup. Was there a significant difference? How bad does the fuel usage get?
Sent from my SM-G935V using PLT Nautique mobile app
FYI - Wakemakers now has "exact fit" 650 lb bags for the 2014+ 230. I was about to order something based on what I've learned from this great thread, until I learned about WM's new product. Placed my order yesterday.
And no, these are not designed to accommodate the storage bins.
Sent from my Pixel 2 using Tapatalk
Originally posted by neirbotFYI - Wakemakers now has "exact fit" 650 lb bags for the 2014+ 230. I was about to order something based on what I've learned from this great thread, until I learned about WM's new product. Placed my order yesterday.
I can't recall the exact dimensions, but it's not a traditional rectangular shape -- it's a laser-meaured fit designed to use all of the available space (hence "Exact fit"), which allows for 650 lbs of ballast. I was also told that divider reinforcements aren't needed.
I think there are 2 ports on top, and one for the drain/fill.
Hope this helps. I'll post pics when I get them installed. Can't wait.
Originally posted by Guntersville230
I was thinking of doing this as well...never cruise above 25mph so i could care less about top end.
Did you ever buy the 2079 prop to try? I still havenโt pulled the trigger yet.
I finally took a picture of the 650lb "ExactFIT" upgrade from Wakemakers. We're loving this setup. With these and the belly filled, I'm getting a ton of push way back on the wave -- with only a driver in the boat. I'm 200 lbs and ride a Sweet Spot board.
Looks like a nice fit. Post some video if you can. I still find the boat is best with some mid weight or bow weight. Waiting to pull the trigger on an IBS setup.
Originally posted by lakeeriemonster View PostLooks like a nice fit. Post some video if you can. I still find the boat is best with some mid weight or bow weight. Waiting to pull the trigger on an IBS setup.
