^^^Yep. Mine is similar to that except I don't have the tee (only one vent hole in my custom sacks) and my hose is a little bit longer. I need to figure out how to post pics...
Originally posted by Guntersville230 View PostMy reason to avoid this set-up is that the extra hose/fittings on top would add extra inches on top where I wanted only the bag to butt up to the top storage tray and no hoses/fittings be in contact with it. BUT if i was leaving trays out this would definitely be a better option
Honestly, I dont know...I forgot what the volume water calculation is but if I remember correctly I was shooting for about 700lbs
Originally posted by markj View Post
Water weighs 62.42 lbs per cubic foot so if you were able to fill yours all the way, it would weigh about 675 lbs. Only thing is, that compartment is only 16" wide so yours really is probably more like 635 lbs. Since I sacrificed the trays, I get almost 800 on each side.
So my 2014 230, I finally got my 630 lb bags installed (16x16x50) a few weeks ago, fit perfect, no issues with the tray, and I kept my original plumbing.
With 3 people in the boat, running NSS 2 and speed at 11.8mph:
1) Wave is waist high from the bottom turn to the top
2) The wave will come over the back deck if you stop to fast
What I did, was order a quick connect for the bag with a 90 degree elbow, it is a 1"1/8 off the elbow, so I had to spend some time heating up the 1" hose from wakemakers with a hair dryer, and a lot of elbow grease... They actually sent me a youtube video explaining it, instead of just sending me the hose I ordered from their site, but i made it work, and there is a short tube running from center bag to the engine divider.
Then I had another 1" 90 degree elbow where the original plumbing connects.
I can take pictures if you are interested.
Starboard side had a nasty curl about 15 feet back at 11.3mph, a little bit of starboard lean and more speed cleaned it up a lot.
