2015 SAN 230 piggyback ballast upgrade
  • Neverenough
    • Sep 2012
    • 907
    • Ft. Worth Texas
    • G
    Originally posted by lakeeriemonster View Post
    Any chance you could post some video/photos of the surfwave?
    Having issues posting video. Pm me and I'll text you a few
    • Davew0815
      • Nov 2013
      • 29
      • Austin tx
      As another datapoint, I had a 2014 230 with the ex343 that I weighted with 800lbs of lead mostly in the bow and 750's in the rear. I initially had the 1235 and switched to the 2079 prop because it struggled to get on a plane for wake boarding. I never had an issue with surf speeds. If you only plan to surf with full ballast then the 1235 should be fine.
      • Jeff88
        • Oct 2015
        • 82
        • Indy
        • 2014 SAN 230
        Originally posted by Jeff88 View Post
        Im in the same boat here. 1235 stock prop with 343. Have the 750s plumbed in with wakemakers divider supports. No issues with surfing with 8-10 people. I also took the trays out the first day and put them in the basement. They look nice but we just throw the jackets on top of the bags. No way you can keep the trays in when you completely fill the bags. No bow weight for me.
        I ordered the support brackets right away based on what everyone on here recommended. I'm going to add a couple more divider pins this winter just to keep them from sliding up. Put you certainly need them with the 750s.....they'll bend your stock bracket
        • Jeff88
          • Oct 2015
          • 82
          • Indy
          • 2014 SAN 230
          I'm thinking about ordering the 2079 as a primary prop and keep the 1235 for backup. Was there a significant difference? How bad does the fuel usage get?
          • Guntersville230
            • Aug 2015
            • 419
            • Guntersville, AL
            • 2015 SAN 230
            I was thinking of doing this as well...never cruise above 25mph so i could care less about top end.
            Sent from my SM-G935V using PLT Nautique mobile app
            • thejean
              • Aug 2017
              • 364
              • Calgary, AB
              Subscribing. Great thread!!!!
              • neirbot
                • Jul 2015
                • 94
                • DFW
                • 2016 230
                FYI - Wakemakers now has "exact fit" 650 lb bags for the 2014+ 230. I was about to order something based on what I've learned from this great thread, until I learned about WM's new product. Placed my order yesterday.
                And no, these are not designed to accommodate the storage bins.
                Sent from my Pixel 2 using Tapatalk
                • Guntersville230
                  • Aug 2015
                  • 419
                  • Guntersville, AL
                  • 2015 SAN 230
                  Can u give any input on sizing (HxLxW) and ports.....just interested if they followed this thread and planned accordingly. Post pics when u install so we all can see!!!
                  • neirbot
                    • Jul 2015
                    • 94
                    • DFW
                    • 2016 230
                    I can't recall the exact dimensions, but it's not a traditional rectangular shape -- it's a laser-meaured fit designed to use all of the available space (hence "Exact fit"), which allows for 650 lbs of ballast. I was also told that divider reinforcements aren't needed.
                    I think there are 2 ports on top, and one for the drain/fill.
                    Hope this helps. I'll post pics when I get them installed. Can't wait.
                    • Jeff88
                      • Oct 2015
                      • 82
                      • Indy
                      • 2014 SAN 230
                      Did you ever buy the 2079 prop to try? I still haven’t pulled the trigger yet.
                      • Guntersville230
                        • Aug 2015
                        • 419
                        • Guntersville, AL
                        • 2015 SAN 230
                        I did....however it was at the start of last season and I never switch back to the 1235 for a direct comparison. I DO think it gets on plane better but to me nothing stood out as a "WOW" factor....mostly just bought it as a second prop so I could have a back up and keep my reworked 1235. That probably does nothing to actually answer ur question so my bad there. I really do need to do a day with one prop and switch to the other prop the next day and compare.....to be continued I guess!
                        • neirbot
                          • Jul 2015
                          • 94
                          • DFW
                          • 2016 230
                          I finally took a picture of the 650lb "ExactFIT" upgrade from Wakemakers. We're loving this setup. With these and the belly filled, I'm getting a ton of push way back on the wave -- with only a driver in the boat. I'm 200 lbs and ride a Sweet Spot board.
                          • lakeeriemonster
                            • Jan 2015
                            • 32
                            • Cleveland, OH
                            • 2016 SAN 230
                            Looks like a nice fit. Post some video if you can. I still find the boat is best with some mid weight or bow weight. Waiting to pull the trigger on an IBS setup.
                            • neirbot
                              • Jul 2015
                              • 94
                              • DFW
                              • 2016 230
                              I thought I'd need more bow weight, but I surf at 11.5 and my boys at 12.3, which lengthens the wave quite well.
                              • charlesml3
                                • Jan 2008
                                • 2453
                                • Lake Gaston, NC
                                • 2022 G23
                                Don't your surf tabs retract when you go past 12mph?
