My piggybacks destroyed my C channels bars holding the divider walls. I added wakemakers reinforcement bars horizontally (engine side) and added an extra pin to the rear top corners. I should have added bottom pins as well and perhaps gone vertical with the support bars on bag side.
Anyone know where I can find replacement aluminum C channel bars and replacement divider walls? I could not find them using keyword search on the nautique parts website.
Originally posted by markj View Post
Looks pretty similar to mine.
Leave a comment:
I have a wavemakers 750 that was custom fit for my 2008 230. I'll sell it and the hoses for 150.
Leave a comment:
Originally posted by neirbot View PostI finally took a picture of the 650lb "ExactFIT" upgrade from Wakemakers. We're loving this setup. With these and the belly filled, I'm getting a ton of push way back on the wave -- with only a driver in the boat. I'm 200 lbs and ride a Sweet Spot board.
Sent from my Pixel 2 using Tapatalk
Leave a comment:
Originally posted by charlesml3 View PostDon't your surf tabs retract when you go past 12mph?
One of my boys (twins) likes 12.6 while the other likes 12.3.
Leave a comment:
Originally posted by lakeeriemonster View PostLooks like a nice fit. Post some video if you can. I still find the boat is best with some mid weight or bow weight. Waiting to pull the trigger on an IBS setup.
Leave a comment:
Leave a comment:
Leave a comment:
Originally posted by Jeff88 View Post
Did you ever buy the 2079 prop to try? I still haven’t pulled the trigger yet.
Leave a comment:
Originally posted by Guntersville230
I was thinking of doing this as well...never cruise above 25mph so i could care less about top end.
Sent from my SM-G935V using PLT Nautique mobile app
Leave a comment:
I can't recall the exact dimensions, but it's not a traditional rectangular shape -- it's a laser-meaured fit designed to use all of the available space (hence "Exact fit"), which allows for 650 lbs of ballast. I was also told that divider reinforcements aren't needed.
I think there are 2 ports on top, and one for the drain/fill.
Hope this helps. I'll post pics when I get them installed. Can't wait.
Leave a comment:
Leave a comment:
