I’m pretty sure the even current 2019 210 is running the same hull running surface as the 14 and up. The gel-scheme has changed though
- Mar 2002
- 16454
- Lake Norman
- Mooresville, NC
Jeff this is me how could I be a Guest? Also I don't think I made this post. Is this a glitch in the system? Very odd. like I have been hijacked. Post #54I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I know this is an old thread but wonder if he’s in river mode ? This could throw off the speedo maybe
Sent from my iPad using TapatalkCurrent Correct Craft Boat
Correct Craft Boats Owned
Originally posted by F725 View PostI think everyone checking this thread is curious to find out what's causing the lack of wave and rooster. It may be the prop after all. I've only ever ran the stock props on our 210's.
It was the paddlewheel!
It showed me 3 KPH (!!!) lower speed than actual. I was riding at 19-20 actual KPH (11.5-12 MPH), so wave was flat and got rooster. I took my phone with GPS speedometer app installed and rolled my eyes when I saw the numbers. Thought it's a river current and tried go back-forth, found out that wheel is lying.
Now I just ride at 14.3 KPH (8.6 MPH) by display, which is 17.3 KPH (10.5 MPH) actual speed.
Does anybody know how can I fix this wheel? Maybe these are water plants and I can clean them out?
Originally posted by skullx View Post
Haha, I've finally figured it out.
the little wheel is right under the driver seat wich is kind of a bad place when you have a boat lift.
first I lifted the boat all the way up for being capable of working under.
I see that the lift bar was right on it. Put the boat down, enlarging the boatlift bars that hold the boat larger so they wouldn’t interfere.
lift the boat another time and everything was ok for placement.
The two side « protection » of the wheel was all folded on the wheel. Replace them verticaly with pliers and everything worked fine.
If the wheel is broken it’s really easy to remove it and replace it too. 25$ at your local Nautique dealer.
Hey Guys, I know this thread is a little old but I am looking to get a 2016 SAN 210 for next season and it has the FlyHigh bags installed already, so its will have two 400lbs bags extra in the back and then another 400lbs in the nose under the seats.
Will I need to do anything on the touch panel to have these fill, adjust fill times or anything?
Also my normal crew is myself, my wife and two kids, not alot of additional weight, will the load out above work or should I look at larger locker bags?
I want to keep the storage trays, if I need to upgrade the bags any recommendations?
Originally posted by Izula369 View PostHey Guys, I know this thread is a little old but I am looking to get a 2016 SAN 210 for next season and it has the FlyHigh bags installed already, so its will have two 400lbs bags extra in the back and then another 400lbs in the nose under the seats.
