Thanks for the pics. It appears that the setup is slightly different on the GS20 than the GS22. I assume this has to do with the 2' difference in boat length.
I have just bought the boat December 2019. The boat did come with pro ballast from the factory. I’ll report back early spring on the wake size. I am new to surfing, apart from a few outings on a friend of mine’s MasterCraft X24 (I think).
BTW will Hero 8 connect to the LINC?
wakemakers used my boat to mock up the new system. they installed mine late November. I didn't take any pics as I was just in a hurry to get my boat back under cover before a storm moved in.
I can tell you though, the 800# bags make the wave very big. a decent surf wave (with factory pro-ballast), became a great wave. I can't compare to G because I have never been behind a G, but I can surf this thing just fine and everyone who has surfed my boat thinks it is great!
I had temporary 800s from wakemakers before the new system.
also, if you set your linc screen to have quagga filters installed, the ballast pumps run longer and actually fill the bags without having to recycle them!Last edited by kylant; 01-21-2020, 10:05 AM.
Originally posted by kylant View Postwakemakers used my boat to mock up the new system. they installed mine late November. I didn't take any pics as I was just in a hurry to get my boat back under cover before a storm moved in.
I need to make sure I understand what I’m seeing in those pics.
all they did was “T” in to the hose feeding the OEM bags... just before the hose goes under the deck.... and it’s T’d off to an extra auxiliary bag laid in the locker?
will this work well? Does it generally fill the OEM bag first because it’s lower? Will this drain both bags reliably?2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
Once the bag is full, it fills the whole width of the compartment. The 3” hole allows the bag to fill completely and not squeeze the sharp edges of the clamp between the bag and compartment wall. These bags were installed in place of the factory “pro ballast.” They fit perfect, just need to drill a 3” hole in the compartment wall..
OP, are you saying now that Wakemakers remade these I should be able to buy and actually plug and play? Or is there more to this?
Originally posted by CTNautique View PostOP, are you saying now that Wakemakers remade these I should be able to buy and actually plug and play? Or is there more to this?
They used my boat as a template. I will get into the boat today and take pics.
I have not fully investigated it yet, as I just pulled the boat out of storage last week, then it snowed for 2 days.
I intend to have the boat on the water this week
