Adding Surf Select to 2020 GS22
  • Cosmo
    • May 2018
    • 23
    • CONNECTICUT
    • 2020 GS22 2006 CC Super Air Nautique 210 Limited
    I'm picking up my next boat in a few days. It's a 2020 GS22 that has Pro ballast, but no surf select. When I asked the dealer if I could add this prior to pick up, he told me it would cost $1000 to do that. But I looked at the parts, and the antenna transmitter/receiver is only $400. I believe this boat comes wired for this option. Is that true? If I hook up the transmitter antenna, will the system work with my Garmin watch or do I need other equipment or software to make that work?
    Andy
  • SANonTellico
    • Aug 2014
    • 301
    • Tellico Lake, TN
    • 2022 GS22
    I didn’t order the Surf Select option with my GS22, instead I bought just the module. The dealer installed it when my boat came in.
    https://www.planetnautique.com/Corre...rminCompat.pdf
    There’s a great install video at the very end of the thread below.
    https://www.planetnautique.com/vb5/f...le-watch/page6
    Previously: 2015 SAN 210
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      It's a matter of mounting the SS module to the bulkhead panel, connecting the wiring and then going into the Dealer Menu and set "Surf Select" to "Yes."
      That's it.
      -Charles
      • Cosmo
        • May 2018
        • 23
        • CONNECTICUT
        Charles, Thanks. I'm ordering that soon.
        • Cosmo
          • May 2018
          • 23
          • CONNECTICUT
          So I finally installed the receiver and I have the watch, but the Linc doesn't see the surf select system. It's grayed out. How do I activate it via the dealer menu? Do I need the dealer code? I can make the boat activate the surf select system and can't pair the watch.
          • Cosmo
            • May 2018
            • 23
            • CONNECTICUT
            NVM i found it Code is 9191 then scroll down and activate the Surf Select. It works and it's fun.
