2002 SANTE resto project
  • t.franscioni
    • Jun 2014
    • 715
    • United States
    • 2002 SANTE
    #46
    One last engine part to paint... Used a wheel paint just because it looked like a good color match and was heat resistant to 250F. Also did not require bare metal so was able to just scuff up the old paint that was on it with a scotch bright pad and spray over it. Color came out okay kind of a silver metallic similar to original.
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      #47
      Painted
      • t.franscioni
        • Jun 2014
        • 715
        • United States
        • 2002 SANTE
        #48
        Ok engine is completed finally.... Just need to
        Install all rest of the raw water hoses and tranny cooler which will go on after it goes back in boat.
        • t.franscioni
          • Jun 2014
          • 715
          • United States
          • 2002 SANTE
          #49
          Pics didn't attach....
          • t.franscioni
            • Jun 2014
            • 715
            • United States
            • 2002 SANTE
            #50
            Really happy with the visual outcome of the motor....now just crossing fingers that I have everything correct and it fires up and runs good!
            • glassywaters
              • Jan 2015
              • 221
              • florida
              • none
              #51
              Wow, that's a beauty! Thanks for the write up.
              • d_nodixon
                • Sep 2008
                • 475
                • Hammond, LA
                • 2013 SAN 230
                #52
                Loving it!
                Sent from my VS985 4G using Tapatalk
                2013 SAN 230
                2006 SSN 210 (SOLD)
                • DLafont
                  • May 2009
                  • 340
                  • Gatineau Qc
                  #53
                  Dude, you'll have a brand new looking boat by the end of it. I'M really impressed by the dedication to detail you're putting into this project. It will look amazing once you're done.
                  Previous: 1990 Ski Nautique
                  • t.franscioni
                    • Jun 2014
                    • 715
                    • United States
                    • 2002 SANTE
                    #54
                    That's the goal... A brand new 2002 super air nautique or as close as possible anyway... Luckily I'm just a wanna be wakeboarder otherwise I'm not sure I could stand looking at this thing in pieces for as long as I have. I really like the look and feel of these older nautique wakeboard boats. To me the older late 90s through about 2003 nautiques were the perfect blend of modern technology and tr looks. I just get more pumped seeing a nice late 90s model nautique than I do a new fancy G series. Just my own preference which is why to me it's worth the time and money to do something like this.
                    • markj
                      • Apr 2005
                      • 1194
                      • NorCal
                      #55
                      I guarantee you're inspiring more people than you even know. As these boats age, your project will become a benchmark standard for others to follow and learn from. Thanks for your time spent sharing this with everyone.
                      • t.franscioni
                        • Jun 2014
                        • 715
                        • United States
                        • 2002 SANTE
                        #56
                        Got the carpet out. Left behind lots of old glue that needed to be sanded off.
                        • t.franscioni
                          • Jun 2014
                          • 715
                          • United States
                          • 2002 SANTE
                          #57
                          Bought a cordless dewalt grinder and used an 80 grit sanding wheel which made quick work of the glue clean up. Full face respirator is a must.
                          • t.franscioni
                            • Jun 2014
                            • 715
                            • United States
                            • 2002 SANTE
                            #58
                            Vacuumed up all the dust and its prepped for the new carpet. Might run a pressure washer over the bilge just because it's last chance to get everything really clean while access is easy and there's no concern of damaging the new carpet or anything else.
                            • obd666
                              • Feb 2010
                              • 793
                              • Bostian Heights, NC
                              • 03 SANTE
                              #59
                              wow, great work! and thanks so much for documenting all of it too. it will be amazing when your finished
                              2003 SANTE - "OG 210"
                              • t.franscioni
                                • Jun 2014
                                • 715
                                • United States
                                • 2002 SANTE
                                #60
                                Iv got my roll of bulk carpet in from Christine's and am ready to trace the old carpet I removed but I'm pretty pumped on all this seadeck talk and projects I'm following on here so I'm going back and forth now between keeping it carpet or joining in on the sea deck craze. So i do what I always do when I need to kill time, pull staples and recover seats.... I came across a couple broken seat bases the the previous owner had tried to patch up when he did some recovering so I figure I could include my repair procedure in this thread. Below is the previous owners repair to the stock rear bench seat base. The staples held up as I didn't know it was broken until I pulled off the upholstery cover. The seat foam is glued to the seat base so you have to be careful you don't tear the foam when pulling it off the seat base.
