A d m i n i s t r a t o r
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
- 2025 SAN G23 PNE 1998 Ski Nautique 1985 Sea Nautique 1980 Twin-Engine Fish Nautique
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
Yeah. The template I made didn't fit. It would have looked funny anyway once I saw what it was going to look like.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
Yeah, those are the standard replacements that Nautique supplies for the failing digital gauges. The issue is that they don't send replacements for the four smaller gauges, so you're left with little gauges that don't match the big ones. Mine are all going to match.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
Got the other matching gauges in the mail today, so I installed them this evening and wired everything up.
Here is the new dash with the new matching gauges.
Lights all tested and functional.
On my dashboards, I always try to improve on the factory wiring. I always remove the non-marine spade connectors that the factory used, and install marine-grade ring terminals with heat shrink where possible. This is normally possible everywhere EXCEPT for the light connections on the gauges. Here's the wiring all cleaned up.
This dash is ready to go back in the boat now!I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
This boat is being built to be sold, so I will not be installing PerfectPass unless the purchaser wants it. If that is the case, I will gladly install it.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
- Mar 2002
- 16426
- Lake Norman
- Mooresville, NC
Well, I made the [PAINFUL] decision to pull the gas tank today.
This will give me lots of space to see if I can fix the ballast system. Hopefully now I can get the ballast tanks out and replace any necessary hoses, and that should fix the ballast system. All of the pumps work, but you can't get to the hoses on the bottom of the tanks (the hoses that are cracked) without pulling the gas tank and removing the ballast tanks.
I can also clean everything up better now, which will be nice.
While it is out, I'll go ahead and install the new steering cable and lube the rudder.
Pulling the gas tank was not fun (it took me about two hours, and I have done several before), but it will allow me to fix things properly, so it was the right thing to do. Luckily it was almost empty!
