Hey guys...I'm super excited to restore my (new to me) 1996 Sport Nautique. I want to document my journey here. I've spent the last few weeks reading many of the 90's era restore threads here and on CCF. But I have lots to learn and look forward to including the Nautique community on the process.
About me: Im up in Canada so for those US friends, forgive my "ou" spellings...find the humour in it.
I run my own IT business by day, and attempt to be super dad to my 3 and 6 yo boys and daughter (coming in November). Its time to start surfing soon with them! In the summer I run the wake-boarding program at a local summer camp my family has grown up at. I grew up on boats and want my kids to have the same adventure.
Background
The boat last ran in the water in 2015. That summer the engine started having issues. At cold start it would run fine, but as it heated up it would "bog" down like it wasn't getting enough gas. By the end of the summer it wouldn't even stay on plane once it was warm. (Not firsthand experience...this was provided by a friend who drove it last that summer). I suspect a bad ECM or fuel line issue per threads here at PN.
The following winter mice got into the engine compartment and did some damage to wiring harness. The local Nautique dealer quoted $1800 CAD for a new harness and the summer camp who owned her just parked her as she was replaced with an '08 SV211. She's been parked ever since.
The interior was already pretty bad in 2015, but has gotten worse as she has been in storage the last 4 years. Some of the vinyl appears to have been replaced at some point as the rear couch and engine cover are pure white without original accent colours.
Powerplant
As a 96, she has the PCM 5.8 HO ProBoss with EFI (351w @ 310hp). It appears that the transmission has been replaced with a newer PCM IRM40-2A at 1.258 ratio (vs original 1.23).
She currently has a 4 blade prop. I also have the original 3 blade prop and a spare drive shaft. I'm assuming the drive shaft came off the original tranny.
The front stabilizer fin is bent, the other 2 are fine. Prop and rudder look great.
Big Plans
I want to bring her back to life. The plans include removing the carpet and replacing with teak style SeaDek. Apart from the SeaDek, I'm on the fence about how "original" I will go with the restoration. But more on that later, I'm sure you guys will have plenty of opinions on that one!
Here is the master list of to dos:
Questions to Answer:
![Wink](https://www.planetnautique.com/vb5/core/images/smilies/wink.png)
Background
Powerplant
Big Plans
- Weigh the boat. She is fully synthetic, but some have still reported wet foam.
- Get engine running. Determine compression and leak-down. Does she need a rebuild or new ECM (I think ECM is bad)?
- Repair/replace wiring harness
- Clean out gas tank and ensure fuel pickup and fuel filters are good.
- Pull carpet
- Level floor and seams to prep for SeaDek. Leaning towards black floor like Jeff did with his Ski restoration.
- Gelcoat wet sanding/restoration
- Disassemble windshield and powder-coat
- New decals and pin-striping
- Turn new wooden throttle handle
- New vinyl skins
- Restore gauge needles and lenses
- Remove black paint from rear transom handle bar
- Sand and rebuild teak swim platform
- Replace original tower
- Replace sound system with Roswell Cybox and new speakers
- Add Perfect Pass Stargazer
- Add Fresh Air Exhaust
- Possibly add heater and shower...I'm in Canada after all!
- The ProTec ignition system was only 93-95, correct? From what I can tell, the 96 did not use ProTec, but I'm not 100% sure. How do you tell if you have ProTec system? (Appears no ProTec according to Jeff in another thread)
- Tower mounting holes. What towers use the same mounting holes of the original tower? Mine is badly warped and I never liked the look of the original.
- How Original to restore? I'm on the fence about using the original 96 "Sport Nautique" hull lettering. 96 used the speckled letters which I don't love. In 97 they switched to solid letters that look much better. Or I could go with modern Nautique typeface letters (is that sacrilege?!). Regarding the upholstery, the original seats had "Correct Craft" embroidered. I would much prefer to use either Nautique or the Nautique "N" logo.
- Since I am going with the SeaDek, I'd like to get rid of the carpet on the bases of the front seat bench, the rear sofa and the bottom of the engine cover. I've seen several other restorations that have painted the rough fiberglass with gelcoat or other smoothing paint. All examples of this online still appear to be noticeably rough with significant orange peel. I'd like to get these smooth. Is West fairing compound the best bet here? How hard is it to skim coat and sand down? Could I just use automotive body filler like Bondo? Has anyone else done this? Advice welcome!
- We plan to surf a fair amount as the kids grow. I've already got a wake shaper. I'm wondering if I could put a small ballast sack under the rear couch. It would have to be small and narrow and I'd have to remove the center partitions. Would this be worth it for such a small bag? There is a decent amount of space under the bow for a bow sack. Thoughts?
- Second battery. I'd like to install a second battery on a butterfly switch to power radio and accessories when floating or as bilge backup when docked. There is a built in battery compartment in the floor of the bow. Where have others located a second battery in Sports of this generation?
- Captain's Chair. Current quote from C&S for skins for helm chair are almost $700 US. For that price, I'd think I can source a current generation helm chair with bolster. But I can't find any full chairs from a modern Nautique online. I really want a chair with a bolster.
