Announcement
No announcement yet.
1996 Sport Nautique Restoration Project
  • #46
    Chris Parsons my plan is to try to fair it smooth. I’m spraying the gel coat for both the floor and the engine base. I know it’s a longshot but my hope is to get it’s so smooth that I don’t need to put SeaDek on it. If the imperfections are too visible and I don’t get it perfect then I’ll do what you did and add SeaDek there too...
    Chris, I’m curious what your thoughts are on the black vinyl around the speaker grills From a vinyl design standpoint?
    • #47
      Make sure you use duratec high gloss otherwise it will never be smooth and shiny enough.
      Not sure I understand your question about the vinyl. Call me.
      • #48
        It’s easier to see pictures above in post #43. There are two pictures for each part of the boat. In one picture speakers sit between the gray and white vinyl. In the other picture there is a black accent piece of vinyl around the speakers. I’m just looking for which option you guys think looks better.
        • #49
          I don't think you can go wrong. Personally I like the just gray.
          • #50
            So it's not as easy as you made it look. Lol
            • #51
              Hahahahaha. Yeah, it’s a lot of work. But good job man. I especially like how you did it from the side. It be great if the program truly understood 3D perspective and you can move the model around.
              • #52
                Any chance you’ve located a walk through window?? I also have a 96 sport missing a walk thru and Stachions.
                thanks!
                • #53
                  Updates?
