After a quick test ride this afternoon, this boat went home with its new owner.
A d m i n i s t r a t o r
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
On a 2008, you won't be able to add PerfectPass. The ECU in all 2008 engines was made by eControls, which means ZeroOff is your only option. That's not a bad thing!
Installation isn't too bad. It is mostly plug-and-play.
Here's the install guide: Zero Off Install Guide - Nautique
https://www.zerogps.com/kits/I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by NautiqueJeff View PostJust completed rebuilding the Flight Clips with new bungees. This was not too difficult, and the kits from NP are only about $25 per side. If you need new bungees on your Flight Clips, you should do this!
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
Ha! They are definitely tight. The pieces only go together one way. If you can't start them by hand, you're putting them in wrong.
Check out the third picture in the instructions below. Look for the little arrow, and make sure that's the end you're inserting. Get it started by hand, and then use pliers or vice grips to squeeze it all the way into place.
https://www.nautiqueparts.com/wp-con...eplacement.pdfI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
NautiqueJeff Is that the factory mounting of the sub? Mine is flat on the floor. Wouldn't mind moving it if that's where it should be.
Edit: I crawled under my cover and can now see some screw holes from where it was mounted. What are the chances those screw holes aren't stripped out?I'll probably just leave it be.
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
