I connected a different hard drive into my laptop today and decided I should share some PDF's of the prop puller I Made.
The horseshoe looking plate fits between the prop and the shaft support
The other solid plate butts up against the end of the drive shaft.
I used 4 pieces of threaded rod I had laying around the shop and kept torquing them clockwise. If I did this more often, I'd probably grab 4 3/8" x ~8" bolts and nuts and go to town.
Worked great, no heat or anything else required. If anyone wants the DXF's PM me and I'll share.
