1995 super sport restoration
  • Chris Parsons
    • Aug 2015
    • 195
    • Orlando
    • 1997 Sport Nautique 1995 Super Sport Nautique
    #46
    New bow light. Required one new wire hole ans two new screw holes but the plate hides previous holes.
    Sent from my SM-G986U using Tapatalk
    • Chris Parsons
      • Aug 2015
      • 195
      • Orlando
      #47
      I started working on the seadek walthrough. My seadek provider has a cnc machine and was willing to cut both the pvc sheet and the aluminum piece with it so they and the seadek are the exact same size.
      I first screwed the pvc sheet to the center hatch then counter sunk bolts through both the aluminum plate and pvc.
      The pvc sheet is there for the upholstery guy to have something to staple the vinyl to. Cushion will run up all the way around this plate.
      In the end it will be in this order:
      1. Seadek
      2. Aluminum
      3. Vinyl stapled
      4. Pvc sheet screwed to hatch
      5. Hatch/fiberglass foam core
      Bolts through everything.
      • Chris Parsons
        • Aug 2015
        • 195
        • Orlando
        #48
        This gives a visual representation of how the vinyl ans seadek sandwich will work. Pen and pencil being staples. The vinyl gets staples down to the pvc sheet and the aluminum plate bolts on top hiding the staples.
        • wakeballer
          • Sep 2020
          • 4
          • Waterdown, Ontario
          • 1995 Super Sport Nautique
          #49
          chris Parsons, Looks like your going to need a Speed Control System...
          I updated my 1995 to a smart phone speed controller by NICKiNAV.
          The App also controls your media volume automatically based on your speed and set-point.
          www.nickinav.com
          Click image for larger version  Name:	nickinavDash.jpg Views:	0 Size:	55.7 KB ID:	634231
          • Chris Parsons
            • Aug 2015
            • 195
            • Orlando
            #50
            I added perfect pass.
            • Chris Parsons
              • Aug 2015
              • 195
              • Orlando
              #51
              Bow runner bars deleted. Moved them to the inside edge of the boat.
              • Chris Parsons
                • Aug 2015
                • 195
                • Orlando
                #52
                Finalizing my seadek design today. I got it scanned then used 3D paint to design it. Very time consuming.
                • Chris Parsons
                  • Aug 2015
                  • 195
                  • Orlando
                  #53
                  New rub rail today. Black looks so good.
                  • Chris Parsons
                    • Aug 2015
                    • 195
                    • Orlando
                    #54
                    Working on installing the ballast this week. Pulled all the wire, wired up the pumps, and installed the switches.
                    All that is left is to run the hose.
                    Also did a new dash plate.
                    The ballast switch plate is a temporary fix. Open to suggestions. Would Like it to be more polished/finished. [/IMG]
                    • Chris Parsons
                      • Aug 2015
                      • 195
                      • Orlando
                      #55
                      Switch plate
                      • Chris Parsons
                        • Aug 2015
                        • 195
                        • Orlando
                        #56
                        Before...
                        • Chris Parsons
                          • Aug 2015
                          • 195
                          • Orlando
                          #57
                          Finalizing seadek patter/design.
                          • Chris Parsons
                            • Aug 2015
                            • 195
                            • Orlando
                            #58
                            Refresh of the dash.
                            I'll still be working on a cleaner look for the right switches.
                            • CincinnatiCC
                              • Dec 2014
                              • 156
                              • Cincinnati, OH
                              • Current 2016 SN 200 OB Past 2008 SN 206, 1989 SN 2001
                              #59
                              Looking good!
                              • Chris Parsons
                                • Aug 2015
                                • 195
                                • Orlando
                                #60
                                Yanked the tower for a paint touch up.thinking I'll go haze gray on all of it. Also I'm doing the costal raptor finish which is like a bed liner type material. It should still look nice and will stay nice longer. Age well.
