Hello new member alert!! From Miami just acquired this 2001 SAN, sat for a bit but I'm ready for the challenge!! Already tore the motor apart looks like it was recently serviced super clean very low carbon build up. Ps wtb swim platform any condition thanks!!
Tags: None
I just did my 05 over the last 1.5 years. Its a lot of work, but well worth it. Hit me up if you have any questions on things. I have probably done most of what you are going to need to do.
Congratz!!
Originally posted by Stevemo14 View PostI just did my 05 over the last 1.5 years. Its a lot of work, but well worth it. Hit me up if you have any questions on things. I have probably done most of what you are going to need to do.
Congratz!!
Originally posted by GmtChris88
Owner was recently delivered a 2020 nautique and haven't touched this since it sank
Bellevue WA
Yeah, kind of dropped that one in there like nothing happened. That changes the entire conversation about any troubles the boat has. Hopefully it was fresh water. I bet there's going to be some electrical issues along the way as well......
Originally posted by bturner View PostYeah, kind of dropped that one in there like nothing happened. That changes the entire conversation about any troubles the boat has. Hopefully it was fresh water. I bet there's going to be some electrical issues along the way as well......
Well best of luck.
My first project and first boat I personally owned was a 19' Sea Ray that sank at the dock, mainly out of neglect. No bilge pump, no cover, couple good storms over a weekend and no one checking on the boat. Mine didn't have a happy ending but hopefully yours will.
The biggest obstacle on mine was fuel or more precisely water in the fuel. I couldn't remove the tank so we pumped it as best we could and then spent hours/days trying to get dirt and water out of the system. After getting the engine to run reliably on muffs for 20 - 30 minutes at a time we took it out to the river where it idled well but would stall when you tried to get in on plane as we were still pulling water from the tank under higher fuel loads. This lead to other fuel system issues while trying to clear the water separator which caused a leak then a fire. Not a good day on the water.
Based on my experience I would suggest removing the tank if possible, dumping the contents then performing some serious cleaning/decontamination or complete replacement of the tank. Maybe a bit over the top but after all these years the event has still left an impression on me. My advise would be to be extremely careful and safe when rebuilding the fuel system on a boat that's sunk before.
Sounds like you and NautiqueJeff should get in contact. Unless my memory is wrong, he's got a cracked block Excalibur 330 engine sitting at his place (or soon will). I'd bet all the electronic bits and harness from his engine might just be the ticket you need if you run into problems.
Bellevue WA
I will have that EX330 engine here soon. I am not sure if anything would be compatible with this GT-40 though.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by SilentSeven View PostSounds like you and NautiqueJeff should get in contact. Unless my memory is wrong, he's got a cracked block Excalibur 330 engine sitting at his place (or soon will). I'd bet all the electronic bits and harness from his engine might just be the ticket you need if you run into problems.
whoooops! Failure on my end...I had this boat as an Excalibur....yeah, likely no electronics move to a GT-40.Last edited by SilentSeven; 07-21-2020, 02:44 PM.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
