See this thread for background. https://www.planetnautique.com/vb5/f...2004-sport-216
I started to really get into cleaning up the hull this week.
First off, i scrapped the decals off with a plastic razor blade and handle. THis worked great for everything except the pinstripes. For those I needed some horsepower.
These wheels are great, but they get hot as **** and the torque kills your wrists. It took me maybe 30 minutes to get the pinstrips off of the entire side of the boat.
What i'm starting with then. lots of oxidation and easily visible decal marks.
One run with a wool pad and Meguires 91 rv/marine cut/buff. This stuff is amazing compared to the old 105/205 Meguires where are a right pain in the *** to pull off.
I went through 800 grit, and 1500 grit but still could see the decal marks.
I went down to 600 grit, 800, then 1500. this helped clearing the decal marks. but the sanding marks are all showing. Which means i need to spend more time at each stage.
This is with hand wet sanding. I"m contemplating running a 800 or 1000 grit no a power sander to reduce change of burn through but power through the marks better.
This resulted in the following after buffing. Still have sanding marks but it's MUCH closer to working.
