Decided to go ahead and send this boat off with the new gelcoat guy. Should have it back in about two weeks. Looking forward to it!
Getting there.....
Originally posted by NautiqueJeff View PostDecided to go ahead and send this boat off with the gelcoat guy who did the work on the 2002 Ski Nautique. Should have it back in about two weeks. Looking forward to it!'06 SANTE210 - Current Boat
'06 SV211 TE - Old Boat
'04 Ski Nautique 196 - Old Boat
Took care of the dash on this boat last night.
The old digital gauges had failed (big shocker).
Instead of replacing them with the Nautique kit, I decided to order the Faria Chesapeake gauges, including the GPS speedometer. This kit is about HALF the price of the Nautique replacement speedometer and tach, and instead of using the PerfectPass paddlewheel for speed input, it uses GPS. On top of that, it replaces ALL of the gauges, not just the speedometer and tachometer. That way ALL of the gauges match.
My dash had a mix-and-match set of gauges -- the original digital speedometer and tachometer, original oil pressure and temperature gauges (which never did match the original speedometer and tachometer), and aftermarket Faria fuel gauge and voltmeter that didn't match anything else.
Here are the before and after shots:
BEFORE:
AFTER:
That's a first....not often you hear Jeff bitching about Nautique support. But I agree...the whole Faria gauge replacement thing is a fiasco.
Remind me - does this boat have a gateway box or not? Thinking no...and that's what lets you use this kit?
Edit: BTW, that big yellow warning sticker needs to go. I get that it's "required" but it's really horrible.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
When there is a better, less-expensive, and easier-to-install solution available than what Nautique comes up with, I am all for it! Especially when it makes all of the gauges match.
The only thing about this system is that it requires you to remove all of the spade connectors that the factory used at the gauge connections and replace them with ring terminals. That's not necessarily a bad thing though, since ring terminals are much better. It is time-consuming though.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Not sure what was worse, the bird crap on the before, or the yellow bling on the after ( SilentSeven edit, ha).
Looks super nice, those new gauges pop for sure!
Usually, yes. I end up keeping some of them though.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Got this one back from the gelcoat shop the other day. It is WAY better than it was. They eliminated most of the oxidation, filled in the speedometer pickup holes (it uses GPS now), fixed a big spider crack, and polished it all up.
I pulled the windshield apart today, and will take the frame to the powder coat shop next week.
This one got moved to a trailer that is a better size for the boat. It had been on a 230 trailer.
