removing pulleys from PCM GT40 engine
  • ally606
    • Jul 2007
    • 66
    • Sunny Scotland.......
    All the pulleys on the engine are showing a little surface corission and so are abrading the belts - giving me lots of lovely belt dust everywhere..
    Ideally I want to remove the waterpump pulley, raw water pump pulley, alternator pulley and crankshaft pulley, sand them down and respray each of them. But are any of the pulleys a taper fit on a shaft or are they all just bolt on?
    I don't have a puller so if they are a taper fit, I'll need to repair them in situ.
    Thanks for the help.
    Loch Lomond: Scotland
    \'97 Sport Nautique, sacked and leaded out
    \'90 Mastercraft prostar with camo\' graphics
  • richard
    • Feb 2005
    • 406
    • HK
    removing pullys from GT-40
    The pullys are not taped, I had remove the alternator,circulation pump,crank pully,and ask a local machine shop to copy to aluminium,since that,had not happen shreded belt problem, keeping use iron pulley not a long term solution. (alternator pulley are pretty hard to remove, need take it out of the boat for disasemble.)
