94 Sport- hesitation around 3200rpm
  • TRDon
    • Oct 2007
    • 722
    • MN
    RE: 94 Sport- hesitation around 3200rpm
    The parts are available thru Correct craft on an as needed EFI basis only. It isnt a general public availability from what I have heard. The parts are few and far between and EFI specific so they are limited for as needed replacement for the elisive efi protec setup.
    • TRDon
      • Oct 2007
      • 722
      • MN
      the cold start is not as god with a carb but it can be dialed in relally nicely. Once mine warms up, it restarts and runs as good as an injected engine.
      • bobchris
        Banned
        • Apr 2006
        • 359
        if it is tuned right you won't know the difference between the carb vs. EFI, **** I could just hit the key on mine it it would start hot, cold even after a winters lay-up, pump the throtle once hit the key fires every time.
        • TRDon
          • Oct 2007
          • 722
          • MN
          Re: RE: 94 Sport- hesitation around 3200rpm
          Originally posted by bobchris
          if it is tuned right you won't know the difference between the carb vs. EFI, heck I could just hit the key on mine it it would start hot, cold even after a winters lay-up, pump the throtle once hit the key fires every time.
          :???: I wish mine would do that. I am still having cold start issues
          • my94sport
            • Mar 2008
            • 29
            • orlando,fl
            RE: Re: RE: 94 Sport- hesitation around 3200rpm
            ANYONE FROM ORLANDO???
