2005 SAN gets single 'click' at turn of ignition key
  • craigc0914
    • Jun 2007
    • 37
    battery is fully charged
    replaced starter
    replaced ignition switch.
    no corrosion on battery cable
    What else could it possibly be?
    It starts once in a while, but all other times i just get a click. Power comes on to everything.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: 2005 SAN gets single
    Starter Solenoid. Trace the large wire back from the starter to the solenoid. They are relatively cheap
    Nautiqueless in San Diego
    • nautique210
      • Nov 2004
      • 150
      • Pennsylvania
      Check for a loose ground that leads to the battery.
      2007 210 TE - Maiden voyage 4/25/2008!
      2003 Super Air Nautique all white/blue stripe
      2002 Super Air Nautique white hull/red & black stripe
      1990 Ski Nautique grey hull/red & black stripe
      1987 Ski Nautique cream hull/blue stripe
      1984 Ski Nautique grey/black & grey stripes
      1984 Ski Nautique biegh/brown stripes
      1977 Ski Nautique white/blue letters
      • craigc0914
        • Jun 2007
        • 37
        so the solenoid isnt directly attached to the starter?
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          No not in these boats It is the little black piece that has the red cable from the battery and to the starter. Plus an energizing wire from the ignition. To check it you can take a jumper cable and jump around it. When it clicks though it usually means a low battery. Also check that the ground to the solenoid is good. Sometimes its a wire but usually it is the case of the solenoid itself grounding to the mount.
          • crnviper
            • 9
            I had the same problem with my 2006 SV-211 yesterday. I kept battery tenders on it all winter, yesterday I took it out to the lake and......"click" every time I hit start (ouch). A Marine mechanic at the marina checked the batteries (they tested good) and jumped the solenoid - it cranked right up... He told me I should replace the starter too if going through all the trouble... Any thoughts??? The CC dealer quoted me $285 for the starter...
            • Andrew
              • Aug 2005
              • 891
              • Tuscaloosa, AL
              i wouldn't bother with the starter...... it should work for years without any problems....
              • JUST-IN-TIME
                • 293
                • ON YOUR BOAT
                it is the starter relay
                easy fix
                HUMAN BUILT = HUMAN FIXED
                switchbait.com
                • crnviper
                  • 9
                  Thanks Andrew and Just-in-Time, I'll trouble shoot this weekend and let you know how it turns out.....
                  • JUST-IN-TIME
                    • 293
                    • ON YOUR BOAT
                    if u need the service manual, i got them all for these boats
                    switchbait.com
