zr6 impellar
  • hdultra
    • May 2007
    • 121
    • Alabama
    zr6 impellar
    Just had new impellar put in the boat and took it out for the weekend. I got about one hr on it and the engine started running hot. I pulled the impellar to find a groove cut out in the center of the impellar on every blade and wear about 1/4 in on each side of the groove. Installed my old impellar and got back to the house with the boat running perfect again. The wear looks like the indention of the out side of the impellar housing. So the impellar was the problem but any idea of why the impellar would go out so soon. Boat only started in water the valve is fully open the stariner is clean. Any ideas would help out.
    2010 SANTE 210
    2004 SANTE 210
    1986 2001
    1989 2001
    1992 SNOB
    1987 2001
  • JUST-IN-TIME
    • 293
    • ON YOUR BOAT
    RE: zr6 impellar
    are u using OEM parts?
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
    • hdultra
      • May 2007
      • 121
      • Alabama
      RE: zr6 impellar
      Yes i am using OEM parts. I talked to a couple of other people and they think it might be a hose loose allowing it to suck air into tthe system. I plan to go to my storage unit and check this tomorrow.
      2010 SANTE 210
      2004 SANTE 210
      1986 2001
      1989 2001
      1992 SNOB
      1987 2001
      • JUST-IN-TIME
        • 293
        • ON YOUR BOAT
        RE: zr6 impellar
        yes i have seen that happen
        post some pics
        switchbait.com
        • jos
          • 154
          • Netherlands Boxtel
          RE: zr6 impellar
          Check all OEM parts.
          I had a new impeller replaced by an OEM piece last year for my 2003 SAN.
          Checked out that the mounting hole had double the permitted tolarance on the axis.
          Giving a rattle sound iddling.
          Air leaks at the suction side of the pump can casue a lot of trouble, airleak means no water pulled in at iddling.
          Check, hose clamps, cut hoses in the clamp area, for sure aged boats and also strainer air leaks.
          Had a major air leak on the inline trans oil cooler, causing above symptom, only when iddling.
          • hdultra
            • May 2007
            • 121
            • Alabama
            pics of impellar
            2010 SANTE 210
            2004 SANTE 210
            1986 2001
            1989 2001
            1992 SNOB
            1987 2001
            • JUST-IN-TIME
              • 293
              • ON YOUR BOAT
              feel inside your housing also
              switchbait.com
