RE: " T "
I have had to deal with two different GT-40 motors thet started to have minor overheat problems, both with high hours, more than 1000. Replacing the raw water pump solved the problem.
The raw water pump is the one with the rubber impeller that is driven by a belt on a GT-40 motor.
If my memory serves me correctly, the raw water pump should fill a 5 gallon bucket in less than 15 seconds, at 3000 engine rpm.
See also this thread:
http://planetnautique.com/index.php?...amp;highlight=
