I'm no mechanic.... but this can't be normal
  • johnjmurray
    • Jun 2007
    • 37
    • Indianapolis, IN
    I tend to agree with Kylant, I assume those manifolds are cast from grey iron which is very prone to corrosion. But I'm open to other thoughts on this matter.
    • Andrew
      • Aug 2005
      • 891
      • Tuscaloosa, AL
      my manifolds have been on "death row" for 7yrs if rust is a sign of failure....... i think ur fine
      • SquamInboards
        • Sep 2005
        • 397
        • Squam Lake, NH
        • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
        I can't recall the last 351 I saw over 3 or 4 years old without some rust on the manifolds... how much rust are we talking about?
        How 'bout a little reverse action...
        • tadelfio
          • Oct 2007
          • 172
          • Bullard, Tx
          Ditto on the manifolds. If the gaskets aren't leaking then leave them alone! They are very expensive to replace if the manifold breaks. If you have to drill out the bolts, then the manifolds are probably pretty rusted and more than likely will break.
