Can't back up my trailer
  • Fast351
    • Oct 2006
    • 315
    • Winsted, MN
    • 2001 Ski Nautique
    Hardest parts are probably getting the lines loose (not sure where you are, but here in MN, everything rusts, even in the summer). Make sure you use a flare nut wrench, not an open ended line. I think there are some hard lines that attach to the solenoid.
    Second is bleeding the brakes. This is just like bleeding car brakes, but it must be done if you open up the system.
    2001 Ski Nautique / 2007 SV211 TE (gone but not forgotten)
    • WakeSlayer
      • Sep 2005
      • 2069
      • Silver Creek, MN
      • 1968 Mustang
      Mine was doing this last year. However, my problem was a bad wire. It had rubbed through on a piece of the trailer frame.
      the WakeSlayer
      1968 Correct Craft Mustang
      • Sundance
        • Aug 2009
        • 1
        • California
        Hey, just checked this site. I have the same problem and after exhausting all possibilities and talking to the Actuator (UFP) guys, I have determined it is the solenoid. Going to change it our this weekend and will let you know unless you have already done it.
        • HS
          • Oct 2007
          • 1333
          • Sammamish, WA
          • 2010 SANTE 210 (Sold)
          Sometimes a faulty ground will prevent the solenoid from "seeing" the reverse light signal. Ask for a "lock out" key for when you get in a jamb.
          • WA-H2O-SKI
            • Jun 2009
            • 77
            • Orondo, WA
            • 2017 Ski Nautique 200 Team - Current Boat
            HS is right on. I wasgoing to suggest that you have a bad ground in the trailer somewhere. It works fine maybe until you get turning of backing in certain conditions. Try just running a jumper ground from the frame of your truck to the trailer. If that makes it work, then just find the faulty ground.
            2003 Ski Nautique 196 LE - Current Boat (Star Gazer w/ ZBox)
            GOODE Flextail 66.5 - Powershell 5 Bindings (LFF)
            PB: 2 Balls @ 39.5' OFF (34.2 MPH Zero Off) Big Dawg Broho Tournament Summer 2015
            1987 Dixie Super Skier 299 - My First Boat
            1987 Barefoot Nautique - Brother's Boat
            1985 Ski Supreme - Dad's Boat
            • steve-o
              • Jul 2009
              • 231
              #21
              You can also "flip" the plug on the trailers to test the solenoid is working. It engages it when the lights are on then.
              • WA-H2O-SKI
                • Jun 2009
                • 77
                • Orondo, WA
                #22
                But, you will be relying on the trailer to ground through the ball on the tow vehicle if you switch the plug around. I would run an alligator clipped line from a known ground on the tow vehicle to the trailer and see if you are fighting a bad ground.
                My trailer ground (wired) went bad and when I turned and headed up my slight driveway incline in reverse, the brakes would lock up. I went looking for bad grounds, purely cause it looked a WHOLE LOT easier than pulling the celinoid out of the togue........
                • TravisFling
                  • Mar 2008
                  • 889
                  • London, Ohio
                  • 1989 Ski Nautique 2001
                  #23
                  that's good advice. I've had a wire go bad before, too. Not on that, but trailer wires are very exposed to the elements, constantly dunked in water, road debris and rocks, etc.
                  Travis Fling
                  Choctaw Lake
                  • AirTool
                    • 4049
                    • Katy, Texas
                    #24
                    The ground can be checked with an ohm meter.
                    • EchoLodge
                      • Jan 2004
                      • 616
                      • Huntington Beach, CA
                      • 99 Super Sport
                      #25
                      I grew tired of messing with the solenoid. Buy the piece that slides in between the actuator.
                      http://www.dhmtrailers.com/online/pr...?productid=883
                      It never fails! Good to have even if you can keep the solenoid working!
                      sigpic
