WHERE exactly is the temperature sender and temp switch??
  • hokiesax
    • Dec 2007
    • 42
    • Fort Walton Beach, FL
    I searched everywhere on this site and couldn't find any descriptions saying where exactly the sender and switch are on a GT-40 (1999 SAN). Can someone describe it and/or post pictures?? Thanks!!!!
  • SquamInboards
    • Sep 2005
    • 397
    • Squam Lake, NH
    • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
    RE: WHERE exactly is the temperature sender and temp switch?
    Not near my boat but below the manifolds on the block, in line with the drain plugs sound familiar.
    How 'bout a little reverse action...
    • hokiesax
      • Dec 2007
      • 42
      is this it?
      is the brass thing in the middle of the picture the temp sender? (wires have been detatched and attached to red wire to ground to check sender)
      • hokiesax
        • Dec 2007
        • 42
        RE: is this it?
        I just talked to Correct Craft and they say that there is no temperature "switch" on these engines.
        • SquamInboards
          • Sep 2005
          • 397
          • Squam Lake, NH
          RE: is this it?
          What do you mean by "switch"? There is a temperature sender which is what makes the needle on you temp guage fluctuate, I don't know about a switch though. Take a look at my gt40 and you can compare it to yours and see if anything is different.
          If you copy the image location and open it in a new window it will be larger and easier to see.
          • hokiesax
            • Dec 2007
            • 42
            RE: is this it?
            Looks like you have a slightly different connector/T coming out the engine, but looks like I guessed right. I talked with the guys at skidim and they said that there is a temperature sender (shown above), and then there is an OPTIONAL temperature switch. I think the switch triggers alarms and bells in case of overheating. I don't know why there would be both, since I thought the sender sends the temp to the gauge and also the red warning light.
            • SquamInboards
              • Sep 2005
              • 397
              • Squam Lake, NH
              RE: is this it?
              So do you have a temp warning light and it's not working or were you just curious?
              • hokiesax
                • Dec 2007
                • 42
                RE: is this it?
                Yeah, read the other post: "GT-40 Temperature Problem (or gauge problem)"
                I guess I should have asked this question in there, but I needed a quick answer and wanted people to see it.
