I Have a 98' Air Nautique & will be gitting it out soon for some spring riding. I was wondering what i should look over or replace before i hit the lake as far as engine & drive train. Thank You!
RE: spring tune up tips?.?.
1. Impeller (if it hasn't been replaced in the past 2 years)
2. Spark Plugs (if they haven't been replaces in a couple years)
3. Change Oil
4. Change Transmission fluid (if it hasn't been changed in last 100 hours)
5. Inspect belts
6. Replace fuel filter
I'm sure others will have a more detailed list, but this is what I follow.Previous:
2011 Super Air Nautique 210
1994 Sport Nautique
- Sep 2005
- 397
- Squam Lake, NH
- '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
What engine? GT-40? in any case, mf01's list is good, if it runs well when you launch it first then that's all you need to worry about. Just be careful the first time you run it to be sure all the hoses and plugs are properly installed, idle the engine to bring it up to temp and check the block, manifolds, with your hand to be sure nothing is getting too hot i.e. not getting water... and no water is leaking anywhere.How 'bout a little reverse action...
inspect alternator can turn feely or not,if belt burn (noise) happenwhen first time start engine,remove the alternator belt,turn the pully by hand to sure it can turn feely,otherwise,need rebuilt. (remove rust and spray rust protectant.)
I have the 94 Pro Boss and the Fuel filter is located near the rear of engine cover. If you look below the port engine cover hinge, you can probably see it. It should look similar to this:
I used the Wix 33033 to replace mine.Previous:
1994 Sport Nautique
