cooling temperature problem,
  • ally606
    • Jul 2007
    • 66
    • Sunny Scotland.......
    Last year I added a heater to the boat (robbed from VW Polo as I'm a cheap skate! )Since then I am getting a low engine coolant temp reading. As part of the heater instal, the temp sender had to be moved from the block and is now placed in line on the feed from the block to the heater matrix. I doubt moving the sender only a few inches would account for a significant drop in coolant temp (originally 140F, now reading 120F).
    I changed the thermostat for a 160F stat, however on the first day out the temp guage reads only barely over 120F (lake water temp 50F).
    Questions, I have the PCM GT40 engine, are there any other locations on the block I can move the temp sender to or alternatively are there other pickups for the hot feed to the heater matrix?
    Here's a photo:
    http://www.pinkbike.com/photo/2001387/
    [/url]
    Loch Lomond: Scotland
    \'97 Sport Nautique, sacked and leaded out
    \'90 Mastercraft prostar with camo\' graphics
  • jos
    • 154
    • Netherlands Boxtel
    RE: cooling temperature problem,
    Ground wire?
    • ally606
      • Jul 2007
      • 66
      does the temp sender need to complete a ground loop ie be grounded itself to provide a reading? If yes, then that's the problem.
      • ally606
        • Jul 2007
        • 66
        okay, ignore the last post. Of course I need to run the sensor to earth.........
        • Rick
          • Mar 2004
          • 1250
          • San Diego, Ca
          Check that you thermostat is opening at 160 and isn't in upside down. That temp sounds like aT-stat problem.
          Nautiqueless in San Diego
