Raw water pump pulley 2002 Ski Nautique 196 with GT-40
  • boo
    • Dec 2005
    • 53
    • San Diego
    • Now: 2002 Ski Nautique 196
    My raw water pump pulley does not line up with the main drive pulley. Because of this, I wear out a lot of raw water pump drive belts. The pump's mount bracket is bolted to a flat area on the engine. It seems like a very thin shim/wedge between the engine block and the mount bracket would work to line up the pulley. Has anyone with a 2002 Ski Nautique 196 with a GT-40 engine experienced this problem? If so, how did you remedy the situation?
    Tom
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    RE: Raw water pump pulley 2002 Ski Nautique 196 with GT-40
    My 2000 is in alignment. I would shim it You might also check that the pulley is on the pump shaft correctly. It may move easily and be able to be brought into alignment
    Nautiqueless in San Diego
