03 SANTE Heater
  • aikenis
    • Jun 2007
    • 114
    • Southport, NC
    03 SANTE Heater
    How warm is the heater supposed to be? Mine doesn't seem to be very warm.
  • ryanc
    • Mar 2004
    • 28
    What temp does your boat run at? I bet it is around 140. When you have a heater it should have the 160 degree thermostat. If the heater was added this happens a lot. Put in the hotter thermostat and you will be cranking some more heat.
    • aikenis
      • Jun 2007
      • 114
      • Southport, NC
      I have no idea. Just check the gauge on the dash? I purchased the boat used a couple of months ago. Where do I purchased the thermostat?
      • SquamInboards
        • Sep 2005
        • 397
        • Squam Lake, NH
        • '82 2001 '84 2001 '86 2001 '98 NSS '87 American Skier
        http://skidim.com/prodinfo.asp?number=RP026002
        How 'bout a little reverse action...
        • ryanc
          • Mar 2004
          • 28
          Yeah when you run the boat next just see what temp it runs at this will tell you which thermostat you have.
          • bchesley
            • Feb 2006
            • 1252
            • Tyler, Texas
            Boats with heaters need the 165 degree thermostat. The instructions on the heatercraft website says so. You can get them in a bunch of places, however, support your local dealer if you have one.
            2001 Super Air Nautique
            Python Powered
            100 Amp Alternator
            Dual Batteries
            Many upgrades coming...
            • aikenis
              • Jun 2007
              • 114
              • Southport, NC
              My boat is running right about 165. What else could be the problem?
              • aikenis
                • Jun 2007
                • 114
                • Southport, NC
                Does anybody know anything about this?
                • Fonseca
                  • Apr 2006
                  • 35
                  • Portugal - Castelo de Bode
                  impeller
                  Hi.
                  Once the engine is hot, try to increse engine rpm to +/- 1800 rpm in neutral and see if water comes hot. If yes you may need to replace your impeller.
                  My heater have this problem and the engine don't overheat at idle.
                  If the problem is not the impeller I sugest you to check the pipe that feeds the heater with hot water as well as the return pipe (look for an obstruction).
                  If you still have no luck try to remove the panel in front of the driver knees and chech if the the hot air pipes are weel connected.
                  Good luck!
                  • aikenis
                    • Jun 2007
                    • 114
                    • Southport, NC
                    RE: impeller
                    I actually just replaced my impeller Friday. The heater was cold on Saturday. I did notice the red hoses you are talking about when I was changing the impeller. So you think there might be a shutoff valve? I know exactly where the heater core is too. I will investigate it soon. Thanks.
