Ok, I have spent sunday trying to get this problem solved without much sucess, so I hope someone can help give me some wisdom on how the power wiring is routed to the dash ignition switch (not ignition key barrel)
The fuses are all ok, there is 12 volts at the starter relay. This terminal doubles onto a smaller gauge wire (red) going into the engine 50amp breaker, I have been unable to get access to the output of this breaker to see if 12 volts are coming out, so here is my questions, before I start taking things off the engine to get into the breaker.
1/Does the 50amp engine breaker feed the dash board?
2/If the breaker has popped out does the button pop out a lot or just a little bit?
3/Has anyone had to replace this breaker?
Oh and the boat is a 98 super sport.
Please help....
Please help....
