2000 SAN Tranny?
  • crotchrocket
    • Aug 2003
    • 86
    2000 SAN Tranny?
    Took the 2000 SAN that I picked up used in December. Well it has been running pretty good. Until today. I felt the tranny slip a few times. Happened worse when I was pulling someone right from the start. The boat was loaded down pretty heavy. I have not checked the fluid level yet. Have any of you guys had this happen Any suggestions as to what it is. I was thinking of going ahead and changing the fluid. What kind of fluid do I need? How many quarts? Any feedback would be appreciated
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    Use a pump, and replace the same amount with what you pump out. Then check the level, use dexron 3. Also check for the smell of the fluid, it will be a good indicator of the amount of heat the tranny has been put thru.
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • crotchrocket
      • Aug 2003
      • 86
      Well I changed the tranny fluid and its not slipping anymore. It was a little low in fluid. Thanks for the advice. I smelled it. Smelled good also looked nice and red.
      • thevogt
        • 117
        • Brandon, FL (Tampa area)
        That is good news! Enjoy the season.
        Gary
