how to pull off trailer rotor
  • rkinsell
    • Oct 2006
    • 27
    I've never pulled off a rotor with sealed bearings. Anyone ever done this?
  • JUST-IN-TIME
    • 293
    • ON YOUR BOAT
    RE: how to pull off trailer rotor
    the rears are always sealed
    HUMAN BUILT = HUMAN FIXED
    switchbait.com
    • AirTool
      • 4049
      • Katy, Texas
      Re: how to pull off trailer rotor
      I don't know....but maybe it is like my 4x4 with sealed bearings....once the caliper is off, the hub-less rotor just falls off. Of course the wheel and lugs have to be off also.
      AirTool
      • rkinsell
        • Oct 2006
        • 27
        RE: Re: how to pull off trailer rotor
        after doing a little research, the part that I am not familiar with is "bearing buddies." Do these just get pulled off and the usual pin and nut are behind the bearing buddy?
        • LT206
          • Mar 2006
          • 262
          • Huntsville, AL
          Yes, take a block of wood and and a hammer and gently tap on both sides of the bearing buddy and you can work it loose - once you get it off there will be the regular guts you are used to seeing.
          • AirTool
            • 4049
            • Katy, Texas
            I guess you must have meant a bearing with seals instead of sealed bearings. Sealed bearings by definition have their own seal and do not get greased.
            I'm thinking what you have is the regular bearings with the separate lip seal in the back.
            Forget the 4x4 analogy I gave. Now that I better understand.
            AirTool
            • JUST-IN-TIME
              • 293
              • ON YOUR BOAT
              i use a rubber mallet or a dead blow, no wood needed
              switchbait.com
              • mf01
                • Jun 2005
                • 515
                • Austin, TX
                Rubber mallet here also. I just hit then moved it a 1/4 turn, hit again, and so on.
                Previous:
                2011 Super Air Nautique 210
                1994 Sport Nautique
