Zr6 Oil leak
  • hdultra
    • May 2007
    • 121
    • Alabama
    Zr6 Oil leak
    Ok i Have an oil leak on my zr6 in my 2004 210. From the best that I can tell its comeing from the base were the oil filter goes when you dont have the relocation kit. Has anyone else had problems like this? Does the base just screw on like a filter? The hoses and crimps look clean so Im pretty sure that it is the base. Thanks
    2010 SANTE 210
    2004 SANTE 210
    1986 2001
    1989 2001
    1992 SNOB
    1987 2001
  • j2nh
    • Dec 2003
    • 628
    • Spread Eagle Wisconsin
    Oil pan
    If your boat came equipped with a quick drain oil kit check the fitting for the hose on the oil pan. Happened to me and on a 196 they have to lift the engine to tighten it. I have the remote oil filter so I can't help you there.
    2018 200 Team H6
    2009 196 Team ZR 409
    2005 196 Limited ZR 375
    2003 196 Limited Excalibur
    1999 196 Masters Edition
    1987 ProStar 190
    • shaun313
      • Oct 2012
      • 7
      • Augusta, Georgia
      • 1997 Sport 2001 SAN 2006 SAN 220
      So are you saying to change quick drain hose that you have to lift engine?
      • dfoster
        • Mar 2012
        • 134
        • Northborough, MA
        • 2004 SV211 TE
        I have an '04 SV211 with the ZR6 and the quick drain hose and I can get my hand on the fitting, so could tighten it without lifting the engine... that said, I would be doing it "blind", so I couldn't really tell if there was a leak. But I have the remote filter too, and the OP says they don't so maybe all bets are off.
        If the issue is around the filter, maybe the seal got messed up. Have you tried just changing out the filter? And check/clean the edge where it seals? Maybe something got nicked the last time the filter was changed?
