Black Sut coming from Tower
  • wakeman777
    • Jan 2007
    • 34
    • Oklahoma
    • 06 - 210 SAN TE
    I have an 06 SAN 210 TE. I have had some black sut coming from where the tower seperates to be folded. What is it & is there anything I can do to eliminate this or does it disipate on its own?
  • AuMDLST
    • Apr 2007
    • 870
    • Orlando, FL (Butler Chain)
    RE: Black Sut coming from Tower
    I believe it is some sort of anti-seize/lube compound that leaks out when moisture enters the joint on the tower - I have the same black stuff on my 06 on occasion as well - separate the tower and wipe clean the area and bolt threads - eventually it will go away - because of the stainless bolt and aluminum tower I give the bolts a turn in and out every time out to keep them free moving
    2006 SANTE 210 (Pending Sale)
    2005 206 TE (Previous)
    • TRDon
      • Oct 2007
      • 722
      • MN
      DO NOT WIPE OFF THE THREADS! It is an anti-sieze compound that is supposed to be on there. If you dont, the different materials (steel bolt/Aluminum tower threads) can gavanize and eat eachother or lock up.
      The black stuff is the part where the 2 aluminum tower surfaces are touching and slightly rubbing. It will happen and also happen when you use an aluminum polish on a wheel or exhaust tip. It is normal, you can wipe that off but not the threads of the tower bolts.
      • AuMDLST
        • Apr 2007
        • 870
        Only will sieze if left for a long period of time - therefore the turning of thebolts every outing
