05 Super Sport Overheating Problem
  • ricoshred
    • Sep 2003
    • 25
    My first boat ride of the seasion, my GT40 is overheating, like the thermostat is sticking. I winterized it myself. Drained all water, antifrz filled motor, etc. Before launching, I installed a new impeller. I have now replaced the t stat 160. It still overheats very quickly. The water seems to flow through the exaust, so I'm pretty sure the impeller is pumping. Any suggestions??? Thanks
  • jward
    • Feb 2008
    • 620
    • Sweet Home Alabama
    • 03 SANTE 04 SANTE
    RE: 05 Super Sport Overheating Problem
    It may be sucking water but only for a short time (loses prime).
    Is it getting so hot that it goes into limp mode or just runs a little hot?
    Check hoses making sure clamps are tight
    Check o-ring on strainer
    Make 100% sure there is no air leak
    Make sure the Raw water Pump is not sucking air (remove pump, put your hand on the discharge end sealing it tight and blow or suck into the intake side to make sure the pump is air tight).
    Good Luck!
    • Laptom
      • Oct 2003
      • 876
      • Eindhoven, Netherlands
      Most likely a vacuum problem. Check what jward says. If the thermostat stucks the engine won't overheating that fast... Check the o-ring on the strainer and make sure the strainer is tight...
      • ricoshred
        • Sep 2003
        • 25
        Thanks guys. You were close. It turns out that the new impeller got chewed up. I replaced it, flushed the debries out, and it's working like normal. I am troubled as to why that would have happened. When I installed it, I'm pretty sure I installed it correctly, spun it in in the correct direction, sprayed it with wd 40 and seemed to spin freely. I did start the boat very very briefly before launching, I'm talking 5 to 10 sec. Do you think that could have done it?
        • AirTool
          • 4049
          • Katy, Texas
          Re: RE: 05 Super Sport Overheating Problem
          1. If you have any scrap pieces of your torn impeller, soak them in a jar of wd-40 and see how the rubber reacts.
          2. There will be many opinions on running the impeller dry. My opinion is don't...not even for 5 seconds. I don't care if your neighbor or brother-in-law does it every trip with great success.
          3. Try loooobing up your new impeller with liquid ivory or dawn soap. Very slippery, stays in there until you run it....then washes out without polluting.
          AirTool
